Ford Passenger Door Won't Open
FORD
CURLYGIRL2424
When I pull on the outside door handle to open the passenger door, it will not open. I have removed the inside door frame and see a rod that is loose.
Do you know of any instructions on how to repair the inside rod?
Mar 19, 2006 at 8:01 AM
PEPPERMRJ
  • 1,158 POSTS
A year and model always help narrow things like this down. :) The rod somehow came off of it's mate. There may or may not be a clip that fell off. Check for it in the bottom of the door.
Good hunting and post back.
Mar 19, 2006 at 8:06 AM
Suggested Repair
The loose rod likely came off its mating point. Check the bottom of the door for a clip that may have fallen off, then reconnect the rod to its mate.
Conversation Summary
The owner of a Ford with unknown year and model says the passenger door will not open from the outside handle. After removing the interior door panel, they found a loose rod and asked how to repair it. The expert said the rod came off its mate and advised checking the bottom of the door for a clip that may have fallen off.
