1999 Ford Tatus, 3.0, SE, 4-door, auto, fwd. How do I determine whether I have a 12 or 24 valve engine? Thanks, John
Sep 10, 2006 at 3:23 AM
Identify the engine by the camshaft layout and valve-cover shape. A single overhead cam with a narrow valve cover indicates a 12-valve engine; two cams under each wide valve cover indicate a 24-valve engine. If the engine is marked Duratec on top, it is the 24-valve version.
The owner of a 1999 Ford Taurus 3.0 SE asked how to tell whether the engine is 12- or 24-valve. The expert explained that a single overhead cam is 12-valve and a double overhead cam is 24-valve, and that wide covers with two cams under each cover indicate the latter while a narrow cover suggests a single cam. A Duratec marking on top of the engine indicates the 24-valve engine.
