2005 Ford Taurus No Crank No Click
SHELLEYB
WE HAD THE STARTER TESTED AND BOUGHT A NEW BATTERY BUT IT STILL WONT CRANK. WHEN YOU TURN THE KEY ON THE LIGHTS,RADIO AND POWER WINDOWS WORK BUT THE STARTER DOESNT EVEN MAKE A CLICKING SOUND. WHAT SHOULD WE TRY NEXT
Jul 25, 2007 at 5:56 AM
SERVICE WRITER
  • 9,123 POSTS
Check all connections to the starter and battery cables. Try holding the key in the crank position while someone taps on the starter. Somtimes jarring a weak starter will get it to start. If so get a starter.
Jul 25, 2007 at 6:01 AM
SHELLEYB
[quote:0162ded563="Service Writer"]Check all connections to the starter and battery cables. Try holding the key in the crank position while someone taps on the starter. Somtimes jarring a weak starter will get it to sta
rt. If so get a starter.[/quote:0162ded563]
WE TRIED THAT BUT IT DIDNT WORK. DO YOU THINK IT COULD BE THE STARTER RELAY ?
Jul 25, 2007 at 7:46 AM
SERVICE WRITER
  • 9,123 POSTS
It may be the ignition switch, the starter, or anything between them, including the relay. You need to find what is getting power but not getting past it.
Jul 25, 2007 at 8:45 AM
Suggested Repair
After confirming battery and starter cable connections and that tapping the starter while cranking did not help, trace the crank circuit to find where power stops. Check the starter relay, ignition switch, and wiring between the switch and starter.
Conversation Summary
A 2005 Ford Taurus will not crank and the starter makes no click, although the lights, radio, and power windows work with the key on. A new battery and a starter test did not fix it. Checking connections and tapping the starter while holding the key in crank also failed. The expert said the fault could be the ignition switch, starter, relay, or anything in between, and advised finding where power is present but does not continue.
