2001 Ford Mustang P0442 EVAP Leak
JESSEG-T
:D Hello,
I was driving my 2001 Mustang GT the highway and my [b:385872a646][u:385872a646]engine sevice soon[/u:385872a646][/b:385872a646] light came on. I took it to auto zone and they checked it with their code device. The computer said my car had a vacuum leak and the auto part guy said it was a small leak in the hoses. Well i don't have that much time with work and school. Where so the most common vacuum leaks occur so i can pin point them ASAP? If you can please help me out with that.
Thanks
Jun 13, 2006 at 11:24 AM
TAURUSWHEEL
  • 718 POSTS
Too many possibilities, need tighter info,, what code did they get??? Could be simple as a bad gasket on your gas cap, system checks itself for leaks... get the code number, there's info on here to direct you.
Jun 13, 2006 at 3:34 PM
JESSEG-T
:D EVAP PO442 Emission control system leak.
Jun 14, 2006 at 1:56 PM
TAURUSWHEEL
  • 718 POSTS
Has to do with your evap system, which consists of various hoses, solenoids, gas tank, canister and of course the gas cap.. listed as a small evaporative system leak in the book... first thing I would do is carefully check the gas cap, make sure the gasket is not torn or threads are not crossed,, then check the filler pipe along it's length to make sure it's not damaged,.. check all hoses for disconnection, breaks, unhooked electrical connectors on the related electrical parts,, may take some work on your part to follow the pieces as they wind around the engine,, hopefully it's something you can see, if not there are tests that can be run, most are beyond the driveway mechanic's ability as the dealer uses a specialized evap system tester to find problems that aren't readily apparent
Jun 15, 2006 at 8:26 AM
Suggested Repair
For P0442 (small EVAP leak), inspect the gas cap gasket and threads, the filler pipe for damage, and EVAP hoses and related electrical connectors for cracks, breaks, or disconnection. If nothing is visible, a shop with a specialized EVAP leak tester is needed.
Conversation Summary
A 2001 Ford Mustang GT set an engine service soon light. AutoZone reported a vacuum leak, later identified as code P0442, a small evaporative emissions system leak. The expert said the EVAP system includes hoses, solenoids, the tank, canister, and gas cap, and advised checking the gas cap, filler pipe, hoses, and related connectors before dealer-level leak testing.
