stalls on cold start
92LX
  • 6 POSTS
I have a 92 LX with the 5.0L and a vortech blower. It has 48,000 miles. The problem is on cold start, it starts up but then the rpm drops right off and stalls. The only way to keep running is to give it some gas and even then the rpms bounce from about 1200 - 500 if I can keep it at a constant above 1500 for a few minutes then it smooths out. Engine is not throwing any codes. I have put in a new EGR valve, checked for vaccuum leaks and did a good cleaning on the IAC. I have also ruled out o2 sensors. Does anyone have any other suggestions.
Nov 28, 2007 at 3:44 AM
BLACKOP555
  • 10,386 POSTS
Try a new coolant temp sensor. Also clean teh MAF if you have one on your vehicle, is located on the air intake hoses coming from the air filter
Nov 28, 2007 at 4:25 AM
92LX
  • 6 POSTS
[quote:cdf61beaf8="blackop555"]Try a new coolant temp sensor. Also clean teh MAF if you have one on your vehicle, is located on the air intake hoses coming from the air filter[/quote:cdf61beaf8]
Thanks very much, I will try the new coolant temp sensor. The MAF is brand new.
Nov 28, 2007 at 2:28 PM
BLACKOP555
  • 10,386 POSTS
hope it helps, post back your results!
Nov 28, 2007 at 11:00 PM
92LX
  • 6 POSTS
Put in the new coolant temp sensor and no change...now I am wondering if a vacuum leak could cause this issue...any other ideas out there??
Nov 30, 2007 at 11:58 AM
BLACKOP555
  • 10,386 POSTS
clean up the throttle body, also check all hoses for cracks. i would not say that its vaccum related as it stops after a while, but it could be. try some fuel additives.
Nov 30, 2007 at 1:46 PM
92LX
  • 6 POSTS
I cleaned out the IAC and there was no change is there a chance the IAC itself is shot and is there a way to test?
Thanks for all your help.
Nov 30, 2007 at 1:53 PM
BLACKOP555
  • 10,386 POSTS
yes there is, and here is how you can check it! take off the IAC and examine it for wear, also check for where it goes into the throttle body, it should be smooth and have no marks whatsoever, if there is some scratches on the IAC replace it, if all looks good reinstall and be sure to put NEW GASKETS on or it probably will suck air.
now take out a volt meter and measure the counts with the engine off at the IAC and record and then start the engine and check the counts. post back the results.
Nov 30, 2007 at 11:56 PM
92LX
  • 6 POSTS
Well I decided to just go with a brand new IAC and gasket and there was no change at all...still revs to around 1500 for 5 secs then drops below 500 and stalls...??!!??
Dec 1, 2007 at 2:13 PM
BLACKOP555
  • 10,386 POSTS
i would like you to manually adjust the idle with the screw on top of the throttle body so the engine idles a little higher. sounds like the IAC is functioning by having the initial rev but its just dropping down too low clean out the throttle body where butterfly valve is, and then adjust the idle a bit higher.
Dec 2, 2007 at 12:53 AM
BLACKOP555
  • 10,386 POSTS
also im kind of curious about what sensor you replaced, did you replace the coolant temp sensor that should be located somewhere near the thermostat under the air intake hoses? or did you replace the one located further back and to the side of the engien?
Dec 2, 2007 at 12:56 AM
92LX
  • 6 POSTS
I replaced the coolant temp sensor located in the solid coolant line that comes from the lower intake manifold just by the thermoostat housing.
Dec 2, 2007 at 3:54 AM
BLACKOP555
  • 10,386 POSTS
i cant think of anything else that can cause those symptoms just on cold starts, you may have a bad pcv valve, take it out and shake it if it rattles it is good, if not replace it, you could also have a cracked or rotted rubber elbo that goes from the valve to the air intake.
Dec 2, 2007 at 5:35 AM
