1986 Ford Mustang Cold Start Stall
NOLEMAN
I have an 86 mustang with the standard 2.3L engine with 120,000 miles. When the car is cold, like in the mornings, it will start but will immediately shut off. I can see the tach rev up to 1500rpm and drop until it shuts off. I have to keepit running with the accelerator for about 5 minutes until it warms up and will run on its own. Help
Sep 3, 2007 at 10:01 AM
  • 75,988 POSTS
[quote:4e7cdaa478="noleman"]I have an 86 mustang with the standard 2.3L engine with 120,000 miles. When the car is cold, like in the mornings, it will start but will immediately shut off. I can see the tach rev up to 1500rpm and drop until it shuts off. I have to keepit running with the accelerator for about 5 minutes until it warms up and will run on its own. Help[/quote:4e7cdaa478]
Check the coolant temperature sensor and the Idle speed control device.
Sep 3, 2007 at 10:27 PM
Suggested Repair
Check the coolant temperature sensor and the idle speed control device.
Conversation Summary
The owner of a 1986 Ford Mustang with a 2.3L engine says it starts when cold, revs briefly, then stalls unless the accelerator is held for about five minutes until it warms up. The expert recommends checking the coolant temperature sensor and the idle speed control device.
