2003 Ford Mustang Sugar in Gas Tank
HRICE1985
some put sugar in my gas tank and i am a girl who doesnt know what is going to happen... Can someone please inform me of how much with sugar is needed to effect my car, and what are the effects that are going to happen and how long do you think i have?
I have a 2003 ford mustang and i am not sure what i am dealing with here... HELP PLEASE!
Apr 6, 2006 at 9:48 AM
OILPAN49
  • 18 POSTS
To this day, I don't understand why people mess with other peoples car. Just says 1 thing about them, immaturity. If it's for revenge, lame excuse.
I apologize to hear this happen to you on a very nice ride!
The only way to fix this problem is too remove the gas tank, drain the fuel, clean out the gas tank by dumping some fresh gas into it, shake the tank around and remove the fuel. This will help remove any sugar remaining in the tank.
Did you try and start the car? If you didn't, that's good! DO NOT START THE CAR! Sugar can and will lock up your engine forcing to have you put a new engine in the car. Is the car under warranty? If so, explain to the dealer what happened, maybe they can help you out.
I've never personally been in this situation so I can only say so much.
Just whatever you do, DO NOT TRY AND START THE CAR! If you have already tried to start it and the engine is locked. If the car is under warranty, get it to the shop and have them put in a new engine and redo the fuel system with new fuel pump, lines, filter and proper fittings.
Again, I am really sorry this happened to you. Nice ride and I hope you get it fixed soon -op-
Apr 6, 2006 at 5:22 PM
BUDDYCRAIGG
  • 2,262 POSTS
It can clog the fuel filter or damage the fuel pump and possibly other fuel system items. But it will not destroy the engine.
Mar 23, 2011 at 12:42 PM
Suggested Repair
Do not assume the engine is ruined. Sugar can clog the fuel filter or damage the fuel pump and other fuel-system parts, so drain and clean the tank and inspect or replace the filter, pump, and related fuel-system components as needed.
Conversation Summary
The owner of a 2003 Ford Mustang said someone put sugar in the gas tank and asked how much it takes to cause damage, what the effects are, and how soon they appear. A reply advised not starting the car, draining and rinsing the tank, and incorrectly warned that sugar could lock up the engine. The expert said sugar can clog the fuel filter or damage the fuel pump and possibly other fuel-system parts, but it will not destroy the engine.
