2000 Ford Mustang Oil Smoke After Rebuild
TJ53
Recently rebuilt engine in a 2000 Ford Mustang with 3.8 V-6. The engine was machined and reassembled with new pistons, rings, ect. #3 cylinder si leaking oil so bad as to foul the plug where it will not fire. #6 plug is dirty on inspection, but is still firing. Is it possible that I have a bad valve seal even though they were all replaced, or maybe the rings did not seat on those two cylinders? It puts out a little blue smoke and also has a strong oil smell when it is first started. Thanks for any advice you can give..
Jun 14, 2007 at 6:52 AM
FORDMADZA
question did you rebuild the motor, a local shop rebuild it or was it pulled and taken to a machine shop and they rebuilt it? We will go fom there. Note why was it rebuilt as the motor is a beast!!
Jun 18, 2007 at 8:52 PM
TJ53
The engine was rebuilt because it was doing the same thing. Burning oil and fouling the plug to the point of misfiring. I pulled the engine and and took it to a machine shop. They did all the machine work and put new pistons on the rods. I took all the parts back home and assembled it myself and re-installed it.
Jun 19, 2007 at 12:46 AM
INDYUKE
  • 416 POSTS
The blue smoke and smell sounds like the valve guides are severely worn. New valve guide seals won't do the trick, even if they are the positive contact type. If umbrella type seals were installed, then you could have oil leaking down into the intake runners.
Generally rings that haven't seated won't cause blue smoke at startup. But during hard acceleration...!
Jun 21, 2007 at 5:34 PM
Suggested Repair
Inspect the valve guides for severe wear. New seals alone will not stop oil if the guides are worn, and umbrella seals can let oil into the intake runners. Unseated rings are less likely to cause blue smoke at startup and more likely under hard acceleration.
Conversation Summary
A 2000 Ford Mustang 3.8 V6 was rebuilt because it burned oil and fouled plugs. After the owner assembled it, cylinder 3 fouls its plug and misfires, cylinder 6 is oily, and startup produces blue smoke and an oil smell. The expert attributes startup smoke to worn valve guides rather than new seals or unseated rings.
