2002 Ford Mustang O/D Off Light Flashing
MGT453
2002 Ford Mustang 122000 miles 3.6 litre V6 engine. The O/D Off light will start flashing when driving down the highway. It doesn't do it when just driving around town. What could be causing this? It has also started down shifting hard and when it is cold out and you warm it up, when you put it into gear, it jerks and dies. I have to go out and get into a cold car in order to go anywhere when it's cold.
Mar 19, 2007 at 4:42 AM
TAURUSWHEEL
  • 718 POSTS
Take it to a locally-owned reliable trans shop and have them run diagnostics, the flashing od light is signaling some type of issue with the trans operation... some shops will run free diagnostics or for small fee,,, find a locally-owned shop with good rep, your best bet. does it stall when you put it in gear or come to a stop??? Maybe your torque converter is staying locked up,, good luck
Mar 19, 2007 at 9:39 AM
MGT453
It does not stall when I come to a stop. It does down shift hard and the engine will bog down but not stall. When the stop is complete and just sitting at the red light, the engine idles fine. If it is cold outside and I have had the car "warming up" and I put it in gear, then it stalls. Thanks for the advice!
Mar 20, 2007 at 3:21 AM
Suggested Repair
Have a reputable local transmission shop diagnose the flashing O/D Off light and hard downshifts. The light indicates a transmission operating problem, and a torque converter that stays locked up is one possible cause.
Conversation Summary
A 2002 Ford Mustang with about 122,000 miles flashes the O/D Off light during highway driving but not around town. It also downshifts hard, bogs without stalling when slowing, and can jerk and stall when placed in gear after a cold warm-up, though it idles normally once stopped. The expert advised a diagnostic check at a reliable transmission shop and suggested the torque converter may be staying locked.
