2001 Ford Mustang Clutch Pedal High
STANGV6
My clutch pedal is letting out at the very top. It's just barely engaging. Over the years the pedal has been slowly letting out closer and closer to the top. What does that mean? What would you reccommend to fix it? Someone mentioned a clutch kit. What comes in one of those? Would that do the trick?
Thank You
Happy Holidays
Lee
Dec 22, 2006 at 11:58 PM
2CARPRO JACK
  • 11,533 POSTS
Yep, sounds like its time for a new clutch. A clutch kit contains: Pressure plate, ctutch disc, throw-out bearing and pilot bearing. Be sure to have the flywheel machined so the new disc has a fresh surface.
Dec 23, 2006 at 12:47 AM
Suggested Repair
Replace the clutch with a kit that includes the pressure plate, clutch disc, throw-out bearing, and pilot bearing, and have the flywheel machined so the new disc has a fresh surface.
Conversation Summary
The owner of a 2001 Ford Mustang V6 says the clutch pedal engages only near the top and has gradually moved higher over the years. The expert says a new clutch is needed and explains that a clutch kit includes the pressure plate, clutch disc, throw-out bearing, and pilot bearing, and recommends machining the flywheel.
