Occasional blue/black smoke.
JOSEDIRTE
So i drive a 96' mustang GT with about 117,000 miles on her, with some modifications. Took off the catalytic converter, put on under drive pulleys, intake, you know the small stuff engine wise. Anyways, I can defiantly smell gas and oil burning when idleing and only when i take off, i can see a cloud of blue/black smoke behind the car. Strange thing is, i can have it neutral and give it gas and theres NO smoke. What do think is the problem?
Aug 14, 2007 at 10:33 AM
MISTERMUSTANG
  • 20 POSTS
the problem is fluid is going where its not supposed to go you have a blown head gasket most likely or a cracked head or block i would compresiion check all the cylinders that will probably narrow it down more
Sep 16, 2007 at 8:09 AM
