1988 Ford Mustang No Fuel
TRAVLIN
my 1988 ford mustang is not getting fuel i have narowed it down to a fuel pump shutoff switch that i cant locate can you give me some advise ps the pump works properly when i hook it to the battery but my light tester say's i'm not getting any power to the pump with the key turning any other advise will be helpful also
Jan 28, 2007 at 12:06 PM
SERVICE WRITER
  • 9,123 POSTS
do you have anti-theft??? if so try another key. The reset is usaully on the left rear trunk area behind a panel.
Jan 28, 2007 at 12:11 PM
TAURUSWHEEL
  • 718 POSTS
I believe there is a fuel pump relay within the integrated control module(at least that's what is called on my 87 Taurus).. it's the black box on top of the radiator shroud.. newer models call it the ccrm, constant control relay module.. on the earlier models such as mine i don't believe the individual relays are replaceable, however you can drill out the rivets on the box to expose the inner workings, maybe you can take it further from there..
Jan 28, 2007 at 3:24 PM
Suggested Repair
Check for an anti-theft issue and try another key. Look for the fuel pump shutoff reset in the left rear trunk area behind a panel. Also inspect the fuel pump relay in the integrated control module.
Conversation Summary
The owner of a 1988 Ford Mustang reports no fuel delivery. The pump runs when connected directly to the battery, but a test light shows no power at the pump with the key on. The owner suspects the fuel pump shutoff switch but cannot locate it. One reply suggests checking anti-theft and trying another key, and says the reset is usually in the left rear trunk behind a panel. Another reply discusses a fuel pump relay inside the integrated control module on a similar-era Ford.
