1996 Ford Mustang New Motor Gray Smoke
Suggested Repair
Hold paper at the exhaust to check for oil, water, or other residue, and note the exhaust smell. Run a compression test on all cylinders and compare the results. Gray smoke can be normal while a new motor breaks in; if it continues after about 1,200 miles, repeat the compression test and perform a leak test to confirm the engine is sealed.
Conversation Summary
The owner of a 1996 Ford Mustang with a newly installed motor, plus new plugs, wires, and oxygen sensors, reports gray smoke and earlier idle problems only when the heat or air was on. One reply suggests checking exhaust residue and smell and running a compression test. Another says a new motor may smoke gray during break-in and recommends compression and leak tests if the smoke continues after about 1,200 miles.
