2002 Ford Mustang Won't Start
LOVEABLE
2002 ford mustang 77000miles will not start and it was working fine before i shut it off and i tryed to go out and it dosen't work any more it sound healthy the distrubuter cap is not wet and the battery it is not bad
Feb 23, 2006 at 6:55 AM
PEPPERMRJ
  • 1,158 POSTS
Check the fuses.
Check the fuel filter.
Check the air cleaner.
Check the rollover switch (fuel pump reset button).
You will need fuel and spark for the engine to run. Check for spark at the plugs and fuel at the rail.
Good luck and let us know. :)
Feb 23, 2006 at 7:28 AM
Suggested Repair
Check the fuses, fuel filter, air cleaner, and rollover fuel pump reset switch. Confirm spark at the plugs and fuel at the rail, since the engine needs both to run.
Conversation Summary
A 2002 Ford Mustang with 77,000 miles will not start after being shut off, although it had been running fine. The starter sounds healthy, the distributor cap is dry, and the battery is good. The expert advises checking the fuses, fuel filter, air cleaner, and rollover fuel pump reset switch, and verifying spark at the plugs and fuel at the rail.
