No hot start can be caused by fuel perculating in the cylinders causing you to loose compression. It can also be caused by worn compressioj rings. With that many miles I suspect you need a ring job.
Pne way to tell is to do a wet dry compression test. That will tell you cylinder/ring wear. If it goes way up on a wet test then you need rings.
It is difficult to analyze sitting here at my computer but that is my best professional guess. Good luck
SPONSORED LINKS
Tuesday, April 25th, 2006 AT 11:45 AM
