1994 Ford Mustang No Start
WAYMONDHEMPHILL
my i have a 1994 ford mustang and the car wont start u dont here anything at all there red liquid leaking but there is transmission and powersteering in it
Jun 9, 2007 at 9:01 AM
SERVICE WRITER
  • 9,123 POSTS
It's blood ....you killed it.
It's one or the other, but nothing to do with the no start. May be battery, connection, starter, ignition switch. Start by checking all connections at battery cables.
Jun 9, 2007 at 2:31 PM
Suggested Repair
The red fluid leak is unrelated to the no-start. Begin by checking all battery cable connections, then inspect the battery, starter, and ignition switch.
Conversation Summary
A 1994 Ford Mustang will not start and makes no sound at all. Red fluid is leaking even though transmission and power steering fluid are present. The expert said the leak is unrelated to the no-start and advised checking battery cable connections first, with the battery, starter, or ignition switch as possible causes.
