2001 Ford Mustang Hot No-Start Click
CARGUY2000
2001 mustang gt,50,000miles. When my cars engine is cold like in the morning it always turns on with the first try. When engine is at normal operating temperature and i try to turn it on it rarely does and all i hear is a click and no start. I put the car in 4th push it forward then it turns on. My friend said something about aligning the flywheel to starter.Thats the way it turns on and im trying to figure out what to replace. thanks
Mar 16, 2007 at 4:28 AM
TAURUSWHEEL
  • 718 POSTS
Could be the starter is failing when hot, not uncommon.. nothing to do with flywheel, if there was an alignment issue, you would have chewed up your flywheel, that's some dollars to fix..
Mar 16, 2007 at 10:52 AM
Suggested Repair
Test and likely replace the starter, which can fail when hot. Flywheel alignment is unlikely; a true alignment problem would damage the flywheel.
Conversation Summary
A 2001 Ford Mustang GT starts normally when cold but often only clicks and will not crank when hot. Pushing the car in gear sometimes allows it to start. The owner was told the flywheel might need alignment with the starter. The expert said a starter that fails when hot is a common cause and that flywheel alignment is not the issue, because misalignment would damage the flywheel.
