1995 Ford Mustang No Start
i had a 76 chevy i had to replace the gaskets and there was quit a bit of rust and flakey paint around it i think fell inside the engine ran rough for about a week and i desided to change my oil it did the trick but i guess that could have been something totally different i dont really know
best of luck
Thanks.
Suggested Repair
Confirm the engine cranks and turns by hand, then verify the spark plug wire firing order. Perform a compression test: low readings on all cylinders can indicate a jumped timing chain, while two weak adjacent cylinders suggest a head gasket leak between them. If compression is poor, have the heads pressure-tested and checked for warpage or cracks.
Conversation Summary
The owner of a 1995 Ford Mustang 3.8L replaced the head gaskets after a blown-gasket diagnosis, but a visual check showed no obvious gasket damage. After reassembly the engine ran rough, made an air-like popping noise, then stalled and would not restart. The new plugs looked fouled except one. Experts recommended checking the firing order, compression, whether the engine turns, possible debris in oil passages, and having the heads checked for warpage and cracks.
