1999 Ford Mustang No Start
INKMANMAC
1) 1999 Mustang GT v8 manual trans. 39780 miles
2) purchased the car about two weeks ago from a guy who got the car from his dad
3) car had sat for a year in a garage
4) the day the guy dropped it off he said he had a hard time starting it that morning, he thought it was because the gas was very low . so he filled it with (1/2 ways) with 97 octane.
5) we shut it off and it started right back up no problems , i drove it for a mile seemed ok
6) parked it in a garage for 2 weeks , not yet registered waiting for title
7) tried starting it yesterday , turned over but would not catch, checked the battery the "indicator light" had turned red , so i charged the battery until the light went out and read full charge. tried again same results
8) replaced all eight spark plugs , tried again same results, noticed that the battery had lost some charge, went to sears bought a brand new battery
9) car will not start !!
10) did a OBD II scan no trouble codes came up ?????
begiing to think it may be a fuel issue (pump) what do u guys think , i fit is how does one check , i am a little handy around cars but not really a mechanic
Apr 22, 2007 at 8:25 AM
INKMANMAC
tried what u suggested i am 90% sure i did not hear that humming noise , i am sure i would have heard it if it was present because on my other car its very noticable.Is it difficult to replace the fuel pump ? can you give me instructions ? would be greatly appreciated !
Apr 23, 2007 at 1:08 AM
MERLIN2021
  • 17,250 POSTS
Gotta drop the gas tank...First check the fuses and relays for the pump. under the hood is a power distribution box, relay is in there. Look in owners manual for wich slot!
Apr 23, 2007 at 2:51 AM
INKMANMAC
[quote:6772d3a9bc="merlin2021"]Gotta drop the gas tank...First check the fuses and relays for the pump. under the hood is a power distribution box, relay is in there. Look in owners manual for wich slot![/quote:6772d3a9bc]
IS THE FUEL PUMP IN THE TANK ? ...................
Apr 23, 2007 at 4:09 AM
Suggested Repair
Check the fuel pump fuses and relays in the under-hood power distribution box, using the owner's manual to identify the correct slot. If the pump must be replaced, the fuel tank has to be dropped.
Conversation Summary
A 1999 Ford Mustang GT that had sat for about a year cranks but will not start after two weeks parked. The battery was charged and then replaced, all spark plugs were replaced, and an OBD-II scan showed no codes. The owner did not hear the fuel pump prime and asked about replacement. The expert advised checking the pump fuses and relays in the power distribution box first and said replacement requires dropping the gas tank.
