88 Mustang (manual) reving upon start-up then stalling
RUSTYMUSTANG
  • 1988 FORD MUSTANG
1988 Mustang, 235,000 km. Hi, I will try to explain as best as I can. As soon as I start my car, it'll rev by itself a couple of times and then almost stall. There have been times when it has reved a couple of times then stalled. It stalls in reverse too. This only happens when the car has been sitting for longer than 5 minutes, so it happens alot. I guess it needs to "warm up" first? This has never happened before. Any ideas? Thanks
Saturday, July 8th, 2006 AT 11:31 AM
TAURUSWHEEL
  • 718 POSTS
Any check engine light? Take it to a local autoparts store where they will read the computer for you, make sure you get any codes and write them down. Or buy yourself a reader for about 30 bucks, tell the parts guy what year and make you have, easy to learn. Problem with the older obdI system is it won't necessarily set the check engine light until complete failure or certain parameters aren't being met. That's why getting the computer scanned when the car is running, called keor, key on engine running, is a good idea. As an example, most transmission codes(automatic) will not set the light to come on, however they will be stored in the hard memory from which they can be retreived with a reader. Something with the operation of the engine may show up also in the hard memory that wouldn't set the light. Newer cars, some 95's, all 96 and above, have the newer obdII system which is much more comprehensive.
Saturday, July 8th, 2006 AT 1:03 PM
RUSTYMUSTANG
No check engine light. Thanks, I'll take it in. But a little worried to get ripped off.
Saturday, July 8th, 2006 AT 1:52 PM
TAURUSWHEEL
  • 718 POSTS
Are you keeping this car for any length of time? Like I said above, spend the 30 bucks, get the reader, read the book, learn how to use it, simple. Any repair shop would probably charge a minimum of 75 bucks to hook it up. If you take it to a local autoparts store, most now will scan it for you and tell you the code or codes, no warmup needed with thjese cars, other then maybe a minute or so just to get everything circulating. I do mine about a minute or so, depending on weather conditions, if real cold, I'll let it go for minute and a half or so, then take it easy for a few minutes, that way it all warms up evenly. Let your car sit for 10 mins, trans still isn't up to temp.
Saturday, July 8th, 2006 AT 5:24 PM
