1995 Mustang cuts off while driving
ODUCHCK04
  • 1995 FORD MUSTANG
I have a 1995 Ford Mustang, V6, manual transmission with 182,000 miles. The past couple months I have been having major problems with my mustang. The car will try to cut of while driving it and several occasions it will cut off and will not restart. The RPM will jump down to 0 and then jump back up when it trys to cut off. I have had the car at a mechanics on several occasions and it still is not fixed. I have replaced the Mass Air Flow sensor, Ingnition Control Monitor, Coil Pack, Spark Plugs, Plug Wires, etc. The EGR valve is now reading on the scanner and well as an electrical code? I have been told that the problem could be the computer? Will the computer cause the car to cut off while driving and not be able to restart? The check engine light is also on in the car.
Thursday, September 6th, 2007 AT 8:01 PM
MISTERMUSTANG
  • 20 POSTS
STOP!
I would be checking the fuel delivery system not the bloody airflow Now does it stall when your idleing it in the driveway or just when your rolling down the strasse' If it only happens when its rolling I would check for loose connections to the fuel pump :D
Sunday, September 16th, 2007 AT 2:26 PM
