2005 Ford Mustang stalling
MATTHEWBOX
  • 2005 FORD MUSTANG
  • V8
  • MANUAL
  • 57,815 MILES
I have an '05 mustang with a stage 1 roush package. Recently my car has been stalling when I come to a stop. Other than that the car runs fine.
Saturday, August 28th, 2010 AT 6:47 PM
WRENCHTECH
  • 20,761 POSTS
You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
Saturday, August 28th, 2010 AT 7:11 PM
