2005 Ford Mustang acceleration
VIXMAR
  • 2005 FORD MUSTANG
Engine Performance problem
2005 Ford Mustang 6 cyl Two Wheel Drive Automatic
My car stalled while driving home. I pulled over tried to accelerate while car was idling and it did nothing but dull rev. What should I be looking for, and what should I try first?
Tuesday, July 13th, 2010 AT 12:05 AM
Lack of acceleration, chugging, hesitating, bogging etc. Could be caused by one of the following below:
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Tuesday, July 13th, 2010 AT 1:29 AM
