2001 Ford Mustang No Spark
SALEENSPEEDSTER0311
  • 2001 FORD MUSTANG
  • V8
  • MANUAL
  • 52,500 MILES
Okay, here is the scoop.
I have a 2001 Saleen N/A, I put a Procharger P1SC on it with a bad tune that landed me on the side of the road with a hole in my block. I then started looking for a short block. I came across a 2004 Cobra motor for a descent price and jumped on it. I extended the coil wires and put it in. The car ran but had a tick. Marred piston. I took the motor back out and had it bored, honed and reassembled. I put the motor back in today, NO SPARK, I have fuel, and compression is good. The car turns over and sounds good doing so, but will not start. I changed the Cam Position Sensor and the Crank Position Sensor. I also checked every fuse in the car. I pulled a coil out put a spark plug in grounded it and cranked the motor, NO SPARK. Please help.
Saturday, April 18th, 2009 AT 12:03 AM
JDL
  • 16,098 POSTS
Hello, did the modifications cause any codes to set? Did you check the primary circuits at the coil/s for B+ and ground? Did you check the circuits at the cam and crank sensors?
Saturday, April 18th, 2009 AT 10:47 AM
SALEENSPEEDSTER0311
I literaly checked everything. Power everythere, crank and cam position sensor replaced, everything pointed to the crank position sensor, and I know it was hooked up correct. Here is the kicker, when it was rebuilt, the reluctor ring that the crank positon sensor reads. Was not put back in. It was given back with the parts replaced. Long day ahead of me getting it torn down to block and heads while in the car and then reassembling it again. Thanks for the info I do appreciate it.
Saturday, April 18th, 2009 AT 11:42 AM
