After sitting 6 mo. It may have lost the prime in the fuel pump, try starting fluid, use only a little bit, too much will cause MAJOR problems, test the fuel pump with a prseeure gauge, also when you turn the key to ON, can you hear the pump run for a few seconds? You should!
SPONSORED LINKS
Saturday, December 8th, 2007 AT 8:54 AM
