2001 Ford Mustang cranks but does not start spark is presen
BEYONDPROHIBITED
  • 2001 FORD MUSTANG
  • 6 CYL
  • 91,000 MILES
Cranks but does not start, spark is present, we drove the car into the garage, after a front end repair the car did not start. Safety gas switch located in the trunk is off.
Tuesday, March 10th, 2009 AT 6:59 PM
Do you hear the fuel pump when you turn key to run, if not check the inertia switch, fuel pump relay, and fuse. If you hear the fuel pump check the fuel pressure if its within specs and also check if your getting injection pulses from the injector/s
Tuesday, March 10th, 2009 AT 7:10 PM
