2000 Ford Mustang Compressor cycling
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
INLAND_GUY
Hello, my air conditioning has developed the nasty habit of blowing hot and cold. When I watch the compressor, the clutch will engage for approx 7-8 seconds, then disengage for the same amount of time. This will continue consistently. When I disconnect the a/c pressure switch, the clutch will not engage. Any thoughts? If it is the pressure switch, can this be changed without having to evacuate the system?
Thanks!
Sep 23, 2009 at 5:52 PM
LEGITIMATE007
  • 5,121 POSTS
hi , mostlikey there's not enough pressure in the system which, indicates a small leak, I would first try to top off the system,(least costly), and see what happens, it should cycle less frequently as you fill, use it for a couple of days, if it goes back to cycling frequently then you have a leak, if it cycles less frequently then obviously you dont, if it continues to cycle on and of frequently even after you checked pressure and topped off, then its your switch. I hope I didnt sound to confusing
thanx
joe
Sep 24, 2009 at 5:59 AM
