My passager window don't work. I want to know if there is something I can check before replacing the motor
Thursday, May 1st, 2008 AT 11:26 PM
MASTERTECHTIM
MECHANIC
You can unplug the motor and put a test light across the 2 wires and activate the window switch up and down, the light should light on both up and down, if it does then replace the motor.
SPONSORED LINKS
Friday, May 2nd, 2008 AT 6:03 AM
YELLOWTXSTANG
MEMBER
I agree with mastertech. If you want you could by a new window switch, and power window realy. You won't spend more than 20 bucks and I rather have newer stuff when I replace expensive parts. It turned out on my stang needed just the relay. Saved me from spending $200 on a new motor.
