HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Mustang
Ignition
No Spark
1990 Ford Mustang ignition
DB0778
MEMBER
1990 FORD MUSTANG
Electrical problem
1990 Ford Mustang V8 Two Wheel Drive Automatic
replaced the coil, dist. Cap, and rotor button and still no spark from the coil. The plugs and wires were replaced about a month ago. Need help.
Monday, September 7th, 2009 AT 3:08 PM
DOCFIXIT
MECHANIC
Maybe the TFI-IV module on side of Dist
Monday, September 7th, 2009 AT 3:33 PM
DB0778
MEMBER
Thats what it was, I finally figured it later the other day. Thanks for the help.
Tuesday, September 8th, 2009 AT 8:16 PM
DOCFIXIT
MECHANIC
Your Welcome use us again
Wednesday, September 9th, 2009 AT 2:07 PM
Please
login
or
register
to post a reply.
Related No Spark Content
No Fire To Spark Plugs
I Recently Posted A Question Regarding The Neutral Safety Switch And Whether It Would Be Locking The Ignition. I Bypassed The Nss And Now My...
Asked by
awoodsonIII
1968
FORD MUSTANG
GUIDE
Ignition Spark Check
An engine's ignition system is responsible for igniting the fuel-air mixture inside the combustion chamber and when the ignition process stops the engine will not run....
No Spark No Injector Pulse?
I Have Tested All I Can Find To Test, The Power From The Pcm Is Going To All The Sensors I Have Tested Such As Iat, Tps, Crank And Cam...
Asked by
haskins64d
2003
FORD MUSTANG
1995 Ford Mustang No Spark
When I Got This Car It Had Blown Head Gaskets And Warped Heads. It Would Start. I Replaced The Heads And It Wouldn't Start. The First...
Asked by
mshropshire
1995
FORD MUSTANG
I Have No Spark When I Crank The Car Over
I Changed The Points, Wires, Plugs And Coil. Ran Fine Until I Washed The Engine Down. Now It Wont Start. No Spark At All.
Asked by
gary bangi
7 IMAGES
1966
FORD MUSTANG
No Spark
I Have A 1989 Ford Mustang Lx 125k Miles 5.0 Engine That I Have Just Replaced The Heads And Intake. The Heads And Lower Intake Are From A...
Asked by
blackstang
FORD MUSTANG
VIEW MORE
Ignition No Spark
Ignition Coil System Test Repair - All Cars
Ignition System Testing
