1990 Ford Mustang grayish white smoke smells real rich of g
WILL1972
  • 1990 FORD MUSTANG
  • V8
  • MANUAL
  • 150,000 MILES
I have 1990 mustang v8, 5. Ol 4 bbl holley, 5 speed carbuerater, I just replaced plugs, plugwires, changed oil and filter, the car runs real good and strong, but it wont quit smoking, and the smoke smells like gas, the oil is fine, and the car runs fine, it just wont quit smoking, and when you just crank it up, it has a littlewater come out tailpipe, but when it warms up no water comes out, and I take off the oil cap, and a little blowby comes out, but the blowby smells like gas not oil, what could be the problem? I put I new powervalve in carb, and its a 6 to 8 lb electric fuel pump, and I have a regulater too, I put some marvrl mystery oil in gas, and put about 6 gallons of gas in car, I noticed a little water in tanks, the car set for a a while too, could it just have water and junk that needs to work out fuel sytem? Is it better to drive car around, or just let it idle to burn it off? Also im running a points distributer, I put new points on it, the motor dont miss or sputter.
Sunday, February 22nd, 2009 AT 9:58 PM
RANGERDANGER17
  • 224 POSTS
Try adjusting the carb could be set to rich
white exaust means its cold or its burning anti freeze
water out the tail pipe is normal
keep an eye on your oil in the dip stick if it is white and milky its a blown head gasket
water and junk in the fuel will make it miss not smoke
Wednesday, February 25th, 2009 AT 7:19 PM
