HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Mustang
Ignition
No Spark
SPONSORED LINKS
1989 Ford Mustang NO SPARK TO SPARK PLUGS
FUZZYYMAN
MEMBER
1989 FORD MUSTANG
4 CYL
2WD
AUTOMATIC
150,000 MILES
How to check the coil
Monday, October 13th, 2008 AT 8:06 PM
BMRFIXIT
MECHANIC
Use an ohm meter
check the wire connector and plug at the coil
check it should have power with the key on
I would suspect also the ignition module
did you check the timing belt ?
u should
check the free videos @
https://www.2carpros.com/video.htm
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
SPONSORED LINKS
Monday, October 13th, 2008 AT 8:16 PM
MECHANIC
Check its primary and secondary windings
Monday, October 13th, 2008 AT 8:18 PM
Please
login
or
register
to post a reply.
Related No Spark Content
1989 Ford Mustang No Fuel, No Spark
This Car Ran When Parked (sat 1 Month), New Plugs And An Oil Change Performed. When Started The Plug Wires Were Incorrect, Blew Out The...
Asked by
TangMeister
1989
FORD MUSTANG
GUIDE
Ignition Spark Check
An engine's ignition system is responsible for igniting the fuel-air mixture inside the combustion chamber and when the ignition process stops the engine will not run....
No Fire To Spark Plugs
I Recently Posted A Question Regarding The Neutral Safety Switch And Whether It Would Be Locking The Ignition. I Bypassed The Nss And Now My...
Asked by
awoodsonIII
1968
FORD MUSTANG
No Spark No Injector Pulse?
I Have Tested All I Can Find To Test, The Power From The Pcm Is Going To All The Sensors I Have Tested Such As Iat, Tps, Crank And Cam...
Asked by
haskins64d
2003
FORD MUSTANG
1995 Ford Mustang No Spark
When I Got This Car It Had Blown Head Gaskets And Warped Heads. It Would Start. I Replaced The Heads And It Wouldn't Start. The First...
Asked by
mshropshire
1995
FORD MUSTANG
I Have No Spark When I Crank The Car Over
I Changed The Points, Wires, Plugs And Coil. Ran Fine Until I Washed The Engine Down. Now It Wont Start. No Spark At All.
Asked by
gary bangi
7 IMAGES
1966
FORD MUSTANG
VIEW MORE
SPONSORED LINKS
Ignition Coil System Test Repair - All Cars
Ignition System Testing
Crankshaft Sensor Symptoms
Online car repair manuals
