2001 Ford Focus Won't Start Clicking
BEHLKECJ
my wife's 01 ford focus SE (approximately 80k mi) ran fine a week ago, sat for one week and won't start. Battery seems fine, no smells, no leaks, when I turn the key the instrument panel lights blink on and off along with the click noise coming from the steering column/engine. it's a persistent CLICK CLICK CLICK CLICK as long as I engage the key. Could this be the starter?
Oct 14, 2007 at 8:12 AM
BLACKOP555
  • 10,386 POSTS
seems like battery is very low on life. charge it or jump it if it starts its battery. battery may have a bad cell and would not mean that it would look bad or smell or look like its leaking. if battery checks out good clean and tighten the battery cables and battery posts. if those dont remedy have the starter tested.
Oct 17, 2007 at 1:46 PM
Suggested Repair
Charge or jump the battery; if it starts, replace or further test the battery, including for a bad cell. If the battery tests good, clean and tighten the battery cables and posts. If that does not fix the no-start clicking, have the starter tested.
Conversation Summary
A 2001 Ford Focus SE with about 80,000 miles sat for a week and then would not start. The instrument lights blink and a persistent click comes from the steering column or engine while the key is engaged, with no smells or leaks. The owner suspected the starter. The expert said a weak battery or bad cell is more likely and recommended charging or jump-starting it, then cleaning and tightening the battery cables and posts if the battery tests good, and testing the starter only if those steps do not resolve it.
