Ford Focus Clicks But Won't Start
DAVEHAILEY
When I turn the key over my car just clicks. All my lights work but will not turn over. I cleaned my battery connections and it is still clicking. What else could it be?
Sep 7, 2007 at 11:50 AM
MERLIN2021
  • 17,250 POSTS
Use a voltmeter and check battery volts, 12.6? If OK the solinoid on the starter may be NG, With the headlights on crank the key and see what happens to the lights. Do they dim out? If yes Battery is NG
Sep 7, 2007 at 11:52 AM
Suggested Repair
Check battery voltage with a voltmeter (about 12.6 volts). With the headlights on, try to crank and note whether the lights dim; dimming points to a weak battery. If voltage is good, the starter solenoid may be bad.
Conversation Summary
The owner of a Ford Focus says the car only clicks when the key is turned and will not crank, although the lights work. Cleaning the battery connections did not help. The expert advises checking battery voltage, watching whether the headlights dim during cranking, and suspecting a bad starter solenoid if the battery tests good.
