2002 Ford Focus Roaring Noise
SINATRAANGELL
Just purchased a pre-owned 2002 Ford Focus LX sedan: 78,000 miles. Car seems to run brand new other than a roaring noise coming from the front while traveling down the road. The noise is not there when the car is stopped/idle/parked. It seems to get louder as I slow down and turn the wheels. Also there is an occasional squeak coming from the brakes when I come to a stop. Dealership seems to think it is the rotors or brake pads...but I've had others tell me I am possibly looking at a bad bearing. What do you think? Thanks.
Mar 3, 2007 at 2:44 AM
CHEVY22
  • 1,375 POSTS
hi
the squeak may be coming from the front hub assemly (bearing) and the noise you described sound like a hub assembly , if you have someone do it the wheel has to come off anyway and the brakes can be checked then
thanks
if you are happy with the info please leave feedback we all here do this for free feedback is a way of saying thank you for the help
Mar 3, 2007 at 4:56 AM
Suggested Repair
Inspect the front hub assembly and wheel bearing; the roaring noise and squeak are consistent with a failing hub. With the wheel removed, also inspect the brake pads and rotors.
Conversation Summary
The owner of a 2002 Ford Focus with 78,000 miles reports a front roaring noise while driving that is absent at idle and gets louder when slowing and turning, plus an occasional brake squeak. A dealership suspected rotors or pads, while others suggested a bad bearing. The expert says both noises sound like a front hub assembly and recommends checking the hub, with the brakes inspected when the wheel is removed.
