2002 Ford Focus Low-Side A/C Port
Suggested Repair
Find the low-side service port on the larger suction line, often near the receiver-dryer, along that line, or at the compressor suction side. Charge only from the low/suction side, never the high side, and on a warm day keep pressure at or below about 250 psi so heat does not raise high-side pressure enough to rupture a line.
Conversation Summary
The owner of a 2002 Ford Focus could find the high-side A/C valve but not the low-side valve needed to add refrigerant. The expert said to follow the larger suction line; the low-side tap is usually on that line near the receiver-dryer, somewhere along the line, or at the compressor suction side. Refrigerant should be added only from the suction side, and pressure should not exceed about 250 psi on a warm day because heat can raise high-side pressure and blow a line.
