2001 Ford Focus Fuel Additives
NIKRO000
I drive a Ford Focus 2001 ZX3 and it runs great.
Lately I am reading a lot about using fuel additives every 3000 miles to clean fuel injectors and the fuel system as preventative maintenance. Even though the car runs fine. Is that something that is advisable to do? There are also a lot of articles out there that tell you to keep your hands off those fuel system cleaning additives.
May 4, 2007 at 10:00 AM
SERVICE WRITER
  • 9,123 POSTS
I'll echo that, you can cause more harm by over using them. OFten a lean condition that shouldn't be present will develop. I like to use a particular brand every 15,000, but not necessarily running it through the tank.
May 4, 2007 at 3:11 PM
Suggested Repair
Do not use fuel-system additives every 3,000 miles. Overuse can cause a lean condition. If used, limit them to about every 15,000 miles and do not necessarily run them through the tank.
Conversation Summary
The owner of a 2001 Ford Focus ZX3 that runs well asked whether fuel additives every 3,000 miles are advisable for injector and fuel-system cleaning. The expert advised against overuse because it can cause a lean condition and said they prefer a particular additive about every 15,000 miles, not necessarily run through the tank.
