2006 Ford Focus Diesel in Gas Tank
JENNYJOS
I am so mad at myself, but I recently accidentally filled the tank of my brand new 2006 Ford Focus (1,500 miles) with diesel fuel (yes the nozzle fit and it was on the same pump as the unleaded). I drove about 4 miles and my car completely stalled out.
We brought it back to dealer for repair and am hearing that the minimum for repair of this is going to be $1300.
The Ford technician just told my husband, that if what they're doing now doesn't work (I don't know the exact details), then we're getting into big dollars. What? $1300 is big dollars to me!
Has anyone but me ever done this on a newer car? Should the repair be this extensive and expensive after only driving 4 miles? I never expected this to be such an expensive error!
Do we need a second opinion?
May 9, 2006 at 6:38 AM
LOSONE
  • 1,616 POSTS
It is an expensive repair because the fuel pump, injectors have to be replaced as well as the entire fuel system flushed. You are lucky you didn't blow the engine. $1300 is a good price. I used to charge $2,000 to $2,500
May 9, 2006 at 10:59 AM
Suggested Repair
Replace the fuel pump and injectors and flush the entire fuel system. About $1300 is a reasonable price for this repair.
Conversation Summary
The owner of a nearly new 2006 Ford Focus accidentally filled the unleaded tank with diesel, drove about 4 miles, and the car stalled. The dealer estimated at least $1300 and warned costs could rise. The expert said the fuel pump and injectors must be replaced and the fuel system flushed, noted the engine was lucky not to be damaged, and said $1300 is a fair price compared with typical charges of $2000 to $2500.
