2001 Ford Focus Rear Window Dropped
BUFFMAN
i have a 2001 focus..80,000 or so miles.....
the back window was down half way and my 6 year old was pushing down on it ,and "POP" down it goes... went to take door panel off..cant seem to get it to cooperate..
Question:
what special tools do i need if any ? and on the top ,,are there clips or what holding it on?
Thanks....
Feb 23, 2007 at 2:52 AM
CHEVY22
  • 1,375 POSTS
no special tools really , once the bottom and middile is undone ,there are large screws at the door pull that go to the shell , push the panel up towards the sky and it should pop right off , just dont force too hard as you may not see all of the clips and screws the first time ,
the regulator is what probably broke
keep us informed
Feb 23, 2007 at 3:39 AM
Suggested Repair
No special tools are needed. Remove the lower and middle fasteners, including the large screws at the door pull, then lift the panel upward so the clips release. Do not force it if clips or screws remain. The window regulator is the likely failure.
Conversation Summary
The owner of a 2001 Ford Focus said a rear window dropped fully after a child pushed it while it was halfway down, and asked what tools and clips are needed to remove the door panel. The expert said no special tools are required: remove the lower and middle fasteners and the large screws at the door pull, then push the panel upward to release the clips without forcing it. The expert suspected a broken window regulator.
