My "door ajar" warning light and sensor run on a continuing basis. I'm sure this is for the rear hatch as I've had problems with the latch catching in the past. Also, if I lurch forward quickly or brake quickly the enertia seems to affect the alarm by either turning it on or shutting it off. I called my local ford dealer and the was told to spray wd40 on the latch which did solve the problem but the warning light and alarm continue to ring. Is there a way to disconnect the sensor that seems to be malfunctioning.
Jan 5, 2010 at 4:13 AM
