2002 Ford Focus Driver rear window fell into door
2002 FORD FOCUS
115,000 MILES • 4 CYL • 2WD • AUTOMATIC
OAKESG
Good Day,
The rear driver side window of my 2002 Ford Focus fell into the door. I don't use that window and don't really need it to function; I just need it stay in the up position. What can I do to secure the window in the up position permanently.
Nov 8, 2009 at 3:58 AM
  • 31,937 POSTS
Hi there,
you will need to remove the door trim to access the glass & the regulator, you then should be able to maneuver the glass back into the tracks, make sure that the bolts that hold the tracks are sill in place and if you want to leave the window up permanently, you can wedge e it this a suitable length of timber from the base of the door to the bottom of the glass or regulator.
Mark (mhpautos)
Nov 8, 2009 at 7:44 AM
