2004 Ford Focus cigarette lighter
66,000 MILES • 4 CYL • 2WD • MANUAL
FOCUS NUT
Is there anything other than a blown fuse
that would cause thelighter to not work?
Apr 17, 2010 at 8:52 AM
RENAUDTN
  • 636 POSTS
It could be the outlet itself or a loose/broken wire.
Check for voltage at the connector. If you get 12V but the outlet doesn't work, then replace it. If you don't get 12V, replace fuse. If it still doesn't work check for a loose/broken wire.
Apr 19, 2010 at 8:49 AM
