2004 Ford Focus Water on Floor of car
130,000 MILES • 4 CYL • FWD • AUTOMATIC
PAMOMMY01
The passenger side floor in the front and rear are soaking wet. What could cause this and how much do you estimate it would cost to fix problem in the worst case scenerio? Someone told me it might be the windshield leaking from the bottom.
Nov 4, 2008 at 4:43 PM
  • 31,937 POSTS
Hi there,
Get the cooling system checked just to make sure that the heater is not leaking, run a hose over the screen and check for water leaking in, also check that the A/C drain is not blocked and that the water is not leaking in from the outside air vents, as for cost this is unknown till you pin point the fault.
mark (mhpautos)
Nov 4, 2008 at 9:14 PM
