Car has spark and fuel, you can hear the fuel pump come on. One time out of ten the car will crank and run, but die immediately. The rest of the time in will only turn over. Have tried spraying the better gas into the throttle body will run a little longer but still dies. Have removed the fuel injectors and they look awful. Is there anyway to clean or rebuild the fuel injectors?
SPONSORED LINKS
Tuesday, August 4th, 2009 AT 11:26 PM
