2001 Ford Focus Fan problems
ASHLEY0903
2001 Ford Focus 4 cyl 143 miles
Soo, basically, I know nothing about cars and I'll try to make a little sense out of this.
My car has been overheating and I had a friend who knows about cars a lot look at it. He told me that I first needed to try to replace the fuse for my fan. Supposively, I am suppose to have a fan that turns on automatically when I turn the key to start the car; and that is not happening. Anybody know what the fuse is called or if that is even right??
Any help would be tremendous!
Apr 13, 2009 at 8:05 AM
RENAUDTN
  • 636 POSTS
Well, your friend could be right. There is an electric fan that turns on automatically when your engine reaches a certain temperature. The fan is located in between your radiator and your engine. Your fan doesn’t turn on when you start the car though. It only turns on when extra cooling is needed. One way you can check for fan operation yourself is by turning on your car and turning on your AC full blast; your fan should turn on very quickly (probably a few seconds). If it doesn’t, then you have a problem with your fan indeed. Like your friend suggested, the first thing is to check the fuse: look in your owner manual; it should have a section that describes the fuses. Look which one applies to the fan, go ahead and replace it and see if your fan now comes on. If it still doesn’t check your fan motor: unplug the connector at the motor and apply battery voltage directly to the motor with jumper wires; if the fan comes on, your motor is good. If it doesn’t you either have a bad connection, a bad relay, or your motor needs to be replaced.
When a car overheats, a problem with the fan is only one possibility. You could also have something wrong with your thermostat, water pump, radiator, bad/low coolant (coolant leak?), hoses, head gasket, cylinder heads, etc. Did your friend ruled out all these other possibilities?
Apr 14, 2009 at 5:54 AM
