HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Focus
Engine
Symptoms
Overheat
2001 Ford Focus Engine Overheating
GRAYFOX66
MEMBER
2001 FORD FOCUS
4 CYL
2WD
AUTOMATIC
120,000 MILES
Hello
What is the most probable cause of engine overheating.
Where is the cooling fan relay located on the frame.
Thanks
John
Saturday, June 6th, 2009 AT 5:36 PM
ARGUS
MEMBER
The most common problems causing engine overheating can be found here:
https://www.2carpros.com/first_things/engine_over_heats.htm
Very well done article including pictures.
I could go over the different issues that could be causing it, but that link will take you to a pretty complete QA.
Good luck!
SPONSORED LINKS
Monday, June 22nd, 2009 AT 11:38 PM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
Over Heating Fan Not Coming On
Over Heating A/c Fans Work Not The Cooling Fan Replaced Both Relay 50&30 Fuses & A 2 Amp Fuse Also Cht Sending Unit Fan Resistor & New Pig...
Asked by
John C Thompson
1 ANSWER
1 IMAGE
2001
FORD FOCUS
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
2001 Ford Focus Car Smells Hot
Smells Problem 2001 Ford Focus 4 Cyl Automatic 110000 Miles My Car Smells Hot But Doesn't Actually Overheat. Sometimes The Gauge Will...
Asked by
mindwrker
1 ANSWER
2001
FORD FOCUS
2001 Ford Focus Overheats
Engine Mechanical Problem 2001 Ford Focus 4 Cyl Two Wheel Drive 124000 Miles My Car Keeps Getting Hot When Idles The Temp Goes All The...
Asked by
bevway
1 ANSWER
2001
FORD FOCUS
2001 Ford Focus Overheating
I Forgot To Put Water In My Car And I Took A 2 Hour Trip. The Engine Begin To Give A Burnt Smell And It Also Began To Smoke. I Filled It...
Asked by
minovar
1 ANSWER
2001
FORD FOCUS
2001 Ford Focus Fan Problems
2001 Ford Focus 4 Cyl 143 Miles Soo, Basically, I Know Nothing About Cars And I'll Try To Make A Little Sense Out Of This. My Car...
Asked by
ashley0903
1 ANSWER
1 IMAGE
2001
FORD FOCUS
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test For Leaks
Online car repair manuals
