2000 Ford Focus HELLO
COSMES
Engine Cooling problem
2000 Ford Focus 4 cyl Two Wheel Drive Manual 52 000 miles
How do I replace the engine temperature sensor ?
Nov 1, 2008 at 5:04 AM
  • 110,248 POSTS
Hi:
The sensor is at the back of the engine block. It is beside the alternator but in a recess and VERY tough to access. Because the bolt housing for the sensor is made of brass, it will strip or shear off in the block easily. If you decide to attempt to replace yours, be prepared for the worst. Don't know how much a garage or dealership might charge, but if something goes wrong while they're working on it, at least you know they won't (or shouldn't, anyway) charge you for correcting any mistakes you might have made.
Let me know if this helps.
Nov 20, 2008 at 5:43 AM
