Other Category problem
2000 Ford Focus Engine Size unknown Front Wheel Drive Automatic 62000 miles
2000 Ford Focus ZTS -
Has trouble accelerating ( low acceleration) - using
more gas. Was misfiring but had spark plugs replaced
--Need valve gasket cover replaced as oil is leaking
-- had run it low on gas sometimes and had to use
fuel inj ector cleaner solution but don't know if that
info is uselful. Fuel pump replaced a year ago.
Do I need a compression check? What else?
Carole
Carole
Feb 10, 2008 at 2:57 AM
