1996 Ford Falcon CAR DOSENT START
MANPREET
  • 1996 FORD FALCON
Engine Mechanical problem
1996 Ford Falcon 6 cyl Front Wheel Drive Automatic 6/KM miles
HELLO SIR
MY CAR MAKES A PERFECT SOUND BUT DOES NOT START AS IT DOES WHEN THERE IS NO OIL IN THE CAR ( THERE IS AT LEASRT 15 LITRES OIL IN THE CAR NOW
TA
MANI
Tuesday, November 10th, 2009 AT 7:09 PM
  • 31,937 POSTS
Drain the oil, you should have only 5 liters in it. Also check that the fuel pump is cycling with the ignition on, you should be able to hear the pump run for a few seconds when the key is turned to on, check this first.
Mark (mhpautos)
Sunday, November 15th, 2009 AT 6:52 PM
