ALTERNATOR FAILURES
ICE P
2002 F-350 W/ V-10,DUALLY, 4 DOOR, 104,000 MILES. WILL A BAD ALTERNATOR CAUSE SPARK PLUG COILS TO FAIL? LOST 1ST ALT, #5 COIL FAILED. LOST 2ND ALT, #10 WENT. LOST MY THIRD ALT, #2 FAILED. THEY WERE A BAD BATCH OF ALTERNATORS FROM THE LOCAL REBUILD GUY. THEY COVERED THE ALTS BUT FORD CHARGES $533.00 EACH TIMETO REPLACE THE COIL. YES, I STARTED REPLACING THEM MYSELF NOW.
Nov 28, 2007 at 6:55 AM
FISHERMAN
  • 937 POSTS
[quote:bbebfe3775="ICE P"]2002 F-350 W/ V-10,DUALLY, 4 DOOR, 104,000 MILES. WILL A BAD ALTERNATOR CAUSE SPARK PLUG COILS TO FAIL? LOST 1ST ALT, #5 COIL FAILED. LOST 2ND ALT, #10 WENT. LOST MY THIRD ALT, #2 FAILED. THEY WERE A BAD BATCH OF ALTERNATORS FROM THE LOCAL REBUILD GUY. THEY COVERED THE ALTS BUT FORD CHARGES $533.00 EACH TIMETO REPLACE THE COIL. YES, I STARTED REPLACING THEM MYSELF NOW.[/quote:bbebfe3775]
Hello !!
At least you`re lucky!
High voltage from a faulty alternator can cause severe damage to the ECU and that.. That`s expensive!
High voltage can damage several things and I think your problem was over-voltage or faulty regulator..
Next time get a brand new alternator.. sometimes the cheap gets expensive!
Good Luck!
Nov 28, 2007 at 7:10 AM
