2005 Ford F350 injectores
2005 FORD F-350
71,000 MILES • V8 • 4WD • AUTOMATIC
BEN928
i put new ones in and now it will not start
Jun 28, 2010 at 9:22 AM
TECH1FORD
  • 102 POSTS
make sure the icp sensor is connected, make sure your glow plugs are plugged in and then it does take a while of cranking to get them to start, did you torque the injectors, did you remember to put in the high pressure oil tubes that go under the manifold
Sep 28, 2010 at 6:57 PM
